Simes
I am about to start shaping the bowsprit. The rather large old telegraph pole has some impressive shakes in it. these shakes bisect the circumference of the pole at around 120 degrees spacing. Each is about 1/4 inch wide by 3 to 4 inches deep. The lenth varies between a couple of feet and some 10 feet.
Given that I intend to have a large heavy band around the foot and a heavy cranse iron around the out board end how should I treat the shakes? Fill with Sikaflex? Epoxy putty? Some form of linseed oil paste?
Should I throw the lump of wood away and start again?
Ultimatly the sprit will be painted bright white so colour of the wood / filler does not matter.
Should I be treating the wood with anything prior to painting?
I thought that this was going to be simple.
Many thanks
Many thanks
