SimonA
I've got a single (small) diesel on a shaft, the engine sits on rubber mounts and the shaft doesn't have a flexible mount. The shaft runs through a PSS and then a shaft log which is just a bronze tube, then a cutlass bearing in the shaft bracket.
The shaft is very difficult to turn by hand. I have no vibration or noise. My engine mounts have just been replaced and the mechanic said the alignment is OK. So what would cause the shaft to be so tight?
