Seastoke
Can these be done in the water and how to do ,cheers roy
What is the engine shaft arrangement ?Can these be done in the water and how to do ,cheers roy
If you have ‘trad’ type packing yesCan these be done in the water and how to do ,cheers roy
Aha, now I understand the confusion behind my previous reply.The book says always set engine alignment with the boat is the water as there is no hull flex and the boats hull is equally supported
Or even better, look at Tides Marine first, and then compare their stuff with Fluiten seals.If you are replacing a stern seal and want a good dry seal with no water in the engine room, look at Tides Marine seals.
if no other problem,then the outer locknuts should be slacked off and the inner nuts tightened a tad until the shaft only drips about once per second.Mine are tightened till no drips and then slacked off a flat or two.. inside the gland there will be several rings of square packing material which allow water to cool shaft but prevent water entering bilges. This website is excellent tutor on the mysterious world of stern gear. http://coxeng.co.uk/stern-gear/ It does help if previous owners have not simply jammed extra packing on top of the older stuff which then goes rock hard and is pig to get out.You can change the stern gland packing in the water even if the above is true. If you think shaft is seriously out of alignment you could check with dial gauge inside the boat for cluesWell my starboard seal looks like it has been spraying water around should I tighten the two bolts then take it out and check ,how much should I tighten and I assumed that if it was spraying they must be out of line ,ps can you tell this when you are going forward and what speed and yes Paul would be good to catch up with a beer
You need to buy some more books !Does that matter? Unless I misunderstood the OP question, the answer is clearly NO regardless, in my books...![]()
LOL, books about nautical English, possibly - see my post #8.You need to buy some more books !
I'm not saying they aren't, but as I previously mentioned, Fluiten seals are even better.Its worthwhile engineering out the packed seal and fitting Tides, they are good, good parts supply and reliable.
Apropos, if not "shaft alignment", how would you call the control that you can only make after removing the shaft completely, to check if it's perfectly straight (and possibly straighten it, if necessary)?
It depends. Gravity force alone can be enough to bend the shafts in a boat not used for a long time, but not to the point of creating evident vibrations.Re post #17 ... 'if the shaft was bent' ... crikey, you would surely feel the vibration if that was the case and it would be a no brainer to lift out?
Precisely THAT is one thing not to like - together with the flexible hose, which is solid, but not as much as bronze or s/steel.Water lubricated by a trickle from both engines
What's not to like?
