Shaft noise
redlady
12 Jun 2002
Have 32 Bayliner with 150 Hino diesel. Starboard shaft seems to be noiser lately as in "metal to metal" I fear cutlass bearing in my future! Q: with boat in water is there are clues, signs, methods for pinpointing this? I know haulout and prop-end exam is normal procedure..but am trying to save time. Hurth trans. seems fine..fluid up...shifts fine...noise seems to be after that.
kgi
29 Apr 2002
andros bahamas
get the wetsuit on dive over the side, give the shaft a shake side to side, if the sideways movement is morethan 4mm, or you can feel/hear an audible clonk then the cutlass bearing is shot,you dont happen to have spurs or shaft knives fitted do you, if they come loose they make a racket as well, hope its not expensive cheers keith
ChrisP
21 Aug 2001
South East England
Mark and split the gearbox / shaft coupling and run engine. If no noise the problem is cutlass or rope cutters if fitted. Also check gland packing. If its run dry then it could be the packing burning the shaft.
ChrisP ;o)
What do you mean the sea gull in front's walking !!!
