Shiver Metimbers
Refitting my shaft with new Stuffing Box Cutlass bearing etc I have come across a big problem. With the cutlass fitted in the "P" bracket and the shaft pushed through to the engine coupling, the shaft is hard against the stern tube at the top. To fit the stuffing box and rubber tube, considerable downward force has to be used on the shaft to get it central enough in the stern tube for the rubber hose and stuffing box to fit. At this stage the engine end of the shaft is lined up.
Another approach I tried was to build the shaft up first and fit the Cutlass Bearing last. Without the cutlass in the "P" bracket, the shaft is central in the bracket at the prop end but is 1/4" out at the other, (1/4" out over 3"). To take this sort of misalignment up using the engine mount adjusters would be 1 1/4" this would put far too much stress on the stuffing box and stern tube. Any ideas?
Thanks in advance.
Thanks in advance.
