Shaft diameter
Nauti Fox
28 Oct 2003
Kent
www.facebook.com
Has anyone gone down the road of increasing shaft diameter, or is it prohibitively expensive? One of the problems I've got with re engineing is that I want to run a 2:1 gearbox and bigger props.At the moment I've got 1:1 16" that spin up to 2800 and I think thats a bit on the fast side.Trouble is the shafts are only 1.5 inches diameter and for 2:1 I need 2".
Does anyone know of a good enginneering yard I could talk to,I would rather go by reccomendations if possible.
Thanks, Al.
<hr width=100% size=1>No dear,the water goes in the other one.
burgundyben
28 Nov 2002
Niton Radio
what are your current shafts? 316? could you get away with monel or T-met?
its been done on my boat, from 1.250 to 1.375 inches, think its just nuts and bolts apart from boring the p brackets to take bigger cutlass bearings.
<hr width=100% size=1>My house is for sale, 2 beds, Hamble.
Nauti Fox
28 Oct 2003
Kent
www.facebook.com
Thanks Ben, from what I've been told 2" is the minimum diameter with good material.Where did you get yours done? Got a feeling that with 0.5" increase it will be new brackets etc.
oldgit
6 Nov 2001
Medway
got a couple of local phone no for that oil seal if you still intend fixing the thing?
