GHA
The R & D flexable shaft coupling
datasheet says this..
Which ain't easy with the technodrive gearbox as there is no continuous flange . So what to do, is it OK to turn it round and use the gap between the R&D and the shaft coupling ?
This must be a common install, how does everyone else measure for the alignment?
Installation Procedure for R & D Flexible Couplings
1. Roughly align engine and stern gear without flexible coupling i.e. only two rigid half couplings pushed together.
2. Bolt 'R&D Marine' coupling between the two rigid couplings. Tightening details as below.
3. Check alignment of engine by placing feeler gauges between the RED CONE HEADED BOLT and the rigid half coupling. Repeat for the SAME bolt at 90° intervals by rotating the shaft.
4. If the gap is the same in all four positions, the engine is accurately aligned. Recommended minimum to maximum gap difference: 0.25mm 0.010"
5. Run installation to bring engine compartment to working temperature. Re-check torque settings.
