bluedragon
We're using two hex pin shackles on the anchor/warp/chain and they work well in not jamming in the stemhead, winch or hawse pipe. The only niggle I have is the fact the pins can't be moused, and when new the threads are a little slack until tightened. It may be they will never come loose, but I'd be happier if the thread was "locked" in some way. I've tried two ideas: a) Loctitie thread lock sealant b) PTFE pipe thread tape (the white stuff plumbers use). Both seem viable solutions, but have others used similar or other methods I wonder? Sikaflex or epoxy resin would probably work as well, but might be rather difficult (or impossible) to undo if necessary. Thoughts anyone?
