MM5AHO
In practicing sextant use, used on land where no clear horizon exists, I've been using the technique of a bowl of water on a pedestal. Using the reflected image of the heavenly body, and the actual body, it's possible to measure the angle between the body and its reflection, and that should be double the elevation angle. Halving the meaured angle gives a useable elevation for that body. The reflected image can be a bit dim, so a bit of juggling the shades required.
But I'm wondering about corrections. I've been using the normal set of corrections - Index error, height of eye (count as zero in this reflection case), and atmospheric refraction correction. The question is, should any extra correction be used for the wider angle measured initially?
If I'm halving that angle first, then applying a standard set of corrections to half the measured angle is that enough? Or should I have any other correction for my artificial horizon?
