maxi77
One could always have a stab at checking the error in one's steering compass....![]()
We always checked the bearing of the sun at sunrise and sunset, and woe betide for any OOW who failed to note the result in the log
On most boats the best timepiece is the GPS which is going to be a problem when you need the sextant for real. So it is a good idea to have a couple of watches on board and sync them with the GPS on a regular basis.
I very much agree that practice is the key.
On the subject of time (and apologies for having posted this before) but GPS time can differ from UTC by considerable amounts. For example, when I looked at the website below at the time of posting, the discrepancy was 15 seconds, which is quite a lot in astro-nav. Someone, perhaps can tell us how much. Might it be 15 miles?
http://leapsecond.com/java/gpsclock.htm
Just noticed this at the bottom of the above page
"Global Positioning System time, is the atomic time scale implemented by the atomic clocks in the GPS ground control stations and the GPS satellites themselves. GPS time was zero at 0h 6-Jan-1980 and since it is not perturbed by leap seconds GPS is now ahead of UTC by 16 seconds."
As to how much error 15 seconds will make, I'm not really sure. I guess it would depend what you are taking a sight of as they "move" at different speeds.
leap second difference between GPS and UTC is, I believe, transmitted as part of the GPS message. The standard nmea GPS sentences put out by receivers should be UTC, not GPS time. Time taken from nmea alone without referencing a PPS signal won't be microsecond-accurate but I'd hope my plotter would be displaying time accurate to a couple of seconds.
That's interesting. If what you say is correct, and I don't doubt it, the time shown on the screen of our GPSs is not, strictly speaking 'GPS time' but UTC. I'll try and remember to check it against the GTS next time I'm on board.
To add even more complexity, perhaps I should get the GTS from a DAB radio!
If you want to get really picky you also need to look at TDT (Terestrial Dynamical Time) which is the time reference for the movement of stars / planets / etc. It's linked to UT by the value ΔT, which is currently 66.664995 seconds (ish).
Sorry John, but I am such a careful navigator that I will need a more precise figure than that, he said, tongue in cheek.
