Deefor
Tongue weight, that's the one
. http://www.shorelandr.com/pages/pf_trstep3.htm
From that link:
Q: Can I use a riser plate to increase the towball height ?
A: NO.
Oops.
So what IS one supposed to do when the trailer has a tow hitch height of 550mm, well outside the "normal" range.
I'll stick to my riser plate, I know it works.
I have a twin axle trailer and find that I can make fairly significant adjustments to the nose weight simply by altering the trailer tyre pressures slightly (i.e. front tyres a tad softer than rears to increase nose weight). Just need to be careful of tyre temperature on long runs.
As has been said by many other posters though, nose weight on a twin axle trailer is messy to get right; changes enormously during driving anyway (as the car goes over bumps and dips); and is by no means the only determinant of towing stability anyway (though I agree it helps to have "some")!
I have a twin axle trailer and find that I can make fairly significant adjustments to the nose weight simply by altering the trailer tyre pressures slightly (i.e. front tyres a tad softer than rears to increase nose weight). ...!
The mass of the trailer should be a bit forward of the vector where the tyres are providing lateral resistance.
As others have said, my understanding is that when determining whether a vehicle can tow a trailer, maximum permissable gross weight on the plate of the trailer that is the important number.
If you have trailer with an MGW of 2500 kgs with load, a car rated to tow 1250kgs, it is mynunderstanding that it cannot tow that trailer even if empty and weighing say 500kgs legally.
I've heard this a few times too, but nobody has ever been able to point me at the bit of legislation that says it! To be honest, I'm beginning to think it's one of those motoring myths. Let's face it, just looking at it from a "common sense" point of view, it would be utterly bizarre! It would be like making it illegal to posess a car that was capable of exceeding the speed limit - even though you weren't driving it in excess of the speed limit at the time! What next? Making it illegal to own a car if it isn't capable of carrying all the members in your family and their combned luggage?
I like the idea of adjusting the tyre pressures so the front are lower than the back; they currently are all the same, @ the maximum permissible indicated on the tyre sidewalls. How much difference in pressure makes a difference on your trailer? ; dropping from 60 to 55, or 50 psi perhaps?
Looking at the Directgov website, it does imply that the MAM of the trailer is what matters for driver licencing, so younger drivers who don't have B+E category on their licence could be in trouble. I've not spent any time looking, but haven't found anything else.
I know a copper who tows a RIB, I'll ask him if I see him.
