noswellplease
The two cockpit winches are getting a bit stiff so I guess they need some cleaning and lubrication. As I have never serviced a winch before I'm wondering about the degree of difficulty. There is a allen screw at the base of the cavity which I guess holds the winch drum in place. What I don't facy is springs washers and and spindles all over the place and having to try and reassemble. Question would it be possible to simply remove the drum and lightly clean what I can see then oil and grease, and not dismantle all the moving parts. If there was a qualified person who could do the job I would ask them but there isn't unfortunately. Could some improvement be achivied this way or is more thought needed to make progress? Russ
