capricorn
Hi All,
Serviced my Yanmar 2GM20 (or at least started to) yesterday afternoon. Changed oil and filter, changed belts, replaced impellor, all OK. Had some problems replacing the primary and secondary filters and bleeding the system which I need some help with. Here goes:
- The primary filter is the type with a metal fitting at the top, a filter element underneath and glass bowl at the bottom, all held togethet with a bolt that runs through the middle. I removed the bowl and filter, cleaned bowl, replaced filter element and reassembled. How do I prime it ? There's another bolt on the top of the metal fitting at the top that I imagine is a vent but this is stuck fast and I couldn't move it with a spanner, will try again next week with a wrench after a squirt of WD40. The filter won't self prime with the lift pump. I assume that I need to remove the stuck vent bolt and prime it from there. Any advice on how to prime the filter much appreciated.
- I couldn't loosen off the tightening ring for the secondary filter housing my hand. What tool do people use for this.
- Finally, I couldn't find the zincs, I understand there are 2, one on the head and one on the block. If anyone could post a schematic like someone did for the 1GM last week that would be great.
Many thanks.
Many thanks.
