Helipilot100
Hi I have two of these beasts in my boat and was wanting a ballpark figure for servicing costs. I appreciate there are different levels of service but any indications to someone totally new to this would be great. Thanks
Big warning make sure you use single grade oil, these engines do not like multi grade.
I would be more inclined to buy all the parts from Finning if i call them for information, personally I would feel like I’m taking the p*** if i called them for information then bought elsewhere, no business is there just to provide free information.The OP can check what oil etc is required by calling Finnings. They are the appointed Cat marine service company. Give them a call with your engine numbers and they will confirm the specification. Actually they are ok for spares prices, although eye watering for service charges. I sourced filters from a bus repair garage. These engines were pretty common in buses. I sourced oil from a local oil and fluids supplier. Finnings rebrand Exol 123 50 grade as Cat. I bought the Exol from the oils supplier. 25 litres per engine, about £60 for 25 litres. Probably more now.
If it's the HEUI equipped B model like mine, valve lash is adjusted after first 200 hours and then again every 2000 hours..If I remember these engines are also in need of a valve clearance at about 400 hours.
Correct.If I remember these engines are also in need of a valve clearance at about 400 hours.
2000 hrs sounds a huge delay .400 is pretty normal and inho sensible.But no harm is doing it sooner rather than later .
