Roach1948
Roach was designed with a self-draining cockpit and the only skin fitting was located on the aft starboard quarter. To access this from the inside it was quite a reach in a cramped locker, so I have decided to turn this locker into a dedicated gas locker and use that skin fitting as the gas overboard drain instead (to modern safety regs).
So I now need a new location for the self-draining skin fitting as I was thinking of the transom. The advantage is that I can easily access the seacock from a large Lazarette locker - the down side is I can only get 3" from the top of the cockpit and worried I might hit some transom fastenings when I drill through.
Has anybody has any experience of transom mounted drains close to the waterline? Will she flood when loaded? Any better ideas?
