Wansworth
Here in Spain any ferretaria sells little coils of different sized galvanized wire that would be the best thing,checking it now and then will give you something bosuny to do!
You can get that from toolstation in the UK.
Around Portsmouth, the mooring pro's all weld shackles.
Mousing is not reliable enough.
If you must DIY, then I have found replacing the shackle pin with a bolt and adding an extra locknut to work acceptably. I loctite the threads. Do it up with big spanners. Drill the locknut and wire through that. Only thing that's gone wrong is some git lassooing the mooring and ripping the lock wire off.
The loctited nut and bolt could be undone after a year in the water, threads looked like new.
Agree. I have only just bought my second reel in over 30 years!
Aviation certified stainless lock wire here. It takes a LOT of working to harden it. You can twist it very tightly.
British spec https://www.lasaero.com/products/article/T04IR671X
US spec https://www.lasaero.com/products/article/L00UG6FJP
