kalanka
The plastic cap on raw water strainer. on my Volvo 2003 has seized. It has an O ring and screws into the strainer bowl. I only ever hand tighten, with a smear of silicone grease. Unfortunately, the cap only has four teeth which are a very loose fit to the supplied nylon spanner. I have tried hot water and detergent spray but am nervous about using release oil or other solvents in case I glue the whole thing even worse. I can apply fair force with a filter wrench and there is no sign of movement at all. Any ideas? Thanks
