Mark Taylor
My poor storage of my Tohatsu 3.5 hp outboard now means that I have an outboard that runs, but both of the transom clamps are seized.........what is the best way of freeing off the clamps? Any ideas appreciated!!
Before trying heat try using penetrating oil. Don't force the handles though as they aren't very strong. It's worth removing them so that you can get a spanner onto the clamp and apply a bit of welly.
If that doesn't work, try heat.
That's what I did with my 3.5. As they are riveted on they will need to be drilled out and reattached with a small bolt. This is such a common problem it leaves you wondering why the clamps are made like this. Just cheapskate, like the use of mild steel bolts in the bracket assembly.Don't force the handles though as they aren't very strong. It's worth removing them so that you can get a spanner onto the clamp and apply a bit of welly.
ACF-50 then corrosion block grease
... then the gentle application of hat from an electric heat gun helped.
