[2574]
Do what you can within reason and make sure it is well insured. That’s about all you can do.
and ask your insurance company for their expectation / advice, then you know you are covered..Do what you can within reason and make sure it is well insured. That’s about all you can do.
Attaching security to the boat without damaging it is the problem? Most transoms have a drainage plug; can you cut a hole like that well above the waterline on the transom? Thread a piece of 10mm+ cable through, block off with an eye on one end and attach your shore secure to that? Cable this thick is almost impossible to cut without heavy tools and thieves do not like to spend time on the job.Hmm I've just spent a grand on it. Don't really fancy making it look terrible! Also I might want to sell it one day...
Inside a tube.Where would you suggest hiding a tracker on an inflatable dinghy?![]()
Inside a tube.
A rigger can make this up from scrap cable in 4 minutes. You could secure by using a threaded end already swaged on with half a botle screw attached, the threads wrecked deliberately to prevent unscrewing. Come sale time........at least youll have an item for sale.
PWG
Maybe. Maybe not. Depends on the tracker size and the valve design.Perhaps easier said than done?
