laika
2. Floorboards should be secured against free movement.
What does that mean exactly? Nail them down? How would I then check the bilges, access the bilge pump or access the emergency wine stores?
It’s a shame that so few of those who use the YM forum site actually contribute financially by buying the magazine.List the items from YM. Will make more sense for those haven't a copy.
Could it be as an experienced sailor, you know this stuff therefore don't find it worthy of you? Personally, I learned stacks many tides ago from yacht magazines. Just because I know stuff now, doesn't mean following on generation's should be denied this information. In my opinion......It never ceases to amaze me the stuff that publications like YM and PBO manage to put into their folders of advertisements. All the stuff in the lists is either basic: routine inspection or maintenance that anyone that sails would or should be familiar with and those starting should be learning ie they wouldn't be considering taking a boat out. Yes I know everyone has to learn but stuff like this is better learnt first hand not from the pages of advertising journals masquerading as sailing magazines. It's one of the reasons I stopped reading them years ago.
Deck boards or cabin sole, dear boy.Floor boards with a bit of ingenuity and the correct fixings can be made easily secure but at the same time easily removable. There are lots of things in a boat that should be secured or constrained that aren't and usually end up on the floor, people should be thinking about those as well it just shows the limitation of the article and journalism that they don't form part of the discussion.
Floaters should be in black water tank although preferably tank emptied firstSep. issue of YM posted a comprehensive article of preparing a yacht for sea, with special attention to expected bad weather.
I agree with all items listed, however I would point out some missing actions:
1. Life jackets (presented on the authors picture!) should be prepared, assigned to crew, crotch straps checked, and jackets fitted to user.
3. Check bilge pumps operation, including floaters.
4. Put (in a secure place) a knife in the cockpit.
5. Check/replace/charge batteries in any handheld instrument
Anything else?
No sprayood ever built will withstand REALLY heavy weather including multiple knockdowns. Essentially in those conditions it is a sacrificial bit of kit, like just about anything else stowed on deck, or in some cases bolted on like most of a vane gear. I've been there deep sea. Sometmes thase magazine articles offer advice that is good for ocean passages, but OTT for ordinary sensible coastal cruising.I agree . If you're worried about the structural integrity of your spray hood, then buy a better designed one.
A reasonable point, but my sole boards aren’t going to end up anywhere they shouldn’t be unless I get knocked down or the boat floods. If we take the cost in time and money of adding hinges and catches to all the sole boards vs expected probability of being knocked down x effort of putting them back and risk of them breaking things as they fall if that happens…I think I’m going to be on the losing side with the upgrades. Of course I should probably upgrade to something fancier than a westerly where they come like that out of the factory
I didn’t see batteries mentioned in the YM list, which is surprising. As the heaviest lumps of kit in the saloon they would concern me most in the event of a knockdown. Mine are in boxes secured with heavy straps bolted to a cross member, even so I worry they could come loose in a rough knockdown. From my limited experience, in my only real knockdown one of the off duty crew was nearly mashed by a large heavy Bose speaker (it was the eighties!) that flew across the cabin and embedded itself by his head. IIRC Matt Sheehan said that his dad was fatally injured by a flying baked bean can during the 79 Fastnet.No sprayood ever built will withstand REALLY heavy weather including multiple knockdowns. Essentially in those conditions it is a sacrificial bit of kit, like just about anything else stowed on deck, or in some cases bolted on like most of a vane gear. I've been there deep sea. Sometmes thase magazine articles offer advice that is good for ocean passages, but OTT for ordinary sensible coastal cruising.
I am happy to sail my present boat of similar size in any coastal conditions I would expect t meet without having floorboards secured. Batteries and anything else heavy and sharp yes though. When I long ago experienced a total inversion it was the toolbox that was the cause of considerable grief.
Would ebay newbies buy YM ?I read the whole list as good advice for newbie skippers of eBay specials who are maybe gonna read one thing before cracking off bound for the Azores or whatever; better than nothing. Otherwise it is a list of obvious things that a cautious costal skipper would at all times be on top of, some things needing an eye before leaving port in marginal situations (whatever the skipper judges those to be) and other things being good seamanlike prep and maintenance which we all learn by observation and experience.
Sarcasm is the lowest form of wit. ?Do authorative tombs make grave predictions?
Do you not understand the (huge) difference between sarcasm and puns?Sarcasm is the lowest form of wit. ?You may make grave predictions but I’ll stick to text prediction. ?
