oldsaltoz
Re: Sag in forestay and pivot .......
G'day Nigel,
Re:
<<I'm just trying to figure out how a pivot would reduce sag ?? The problem as we found is that you need to tension each stay as if it was a single - this increases the load on the deck + mast fittings irrespective of single or dual attachments .... This then is unacceptable loading ... well we thought so when tensioning !! A pivot ?? How can that improve it as you still have the two stays ??>>
As I understand it the fact that both stays are fixed to a single pivot at the deck level any tension placed on one would be transferred [via the pivot] to the second stay, so you don't end up with one tighter than the other.
Avagoodweekend...
G'day Nigel,
Re:
Avagoodweekend...
