RichardS
N/A
This is just my thoughts about seawater pumps having had another experience re-lauching a couple of weeks ago and following on from a comment made by
sailaboutVic after his recent re-launch.
It seems that seawater pumps failing to pump reliably is quite a common theme on PBO. Posters have usually changed the impeller but without recifying the
problem. The answer is very often that the seawater filter screw-on lid is not making an airtight seal and remedies such as silicone/vaseline, a new lid, a
tighter lid etc usually seem to remedy the problem.
When we acquired our boat, I replaced impellers and installed Speedseal Life pump covers but still one of the engines would not always prime reliably until
I properly greased the filter lids. They now both seems to be 100% reliable ..... unless the boat has been lifted out of the water, and then all bets are off.
I am guessing that the hit and miss re-priming of the pumps when the boat is lowered back into the water is strongly dependent upon the height of the filter above sea level. My cat sits very high in the water and the filters are well above sea level. I haven't measure it but I'm guessing that the top of the central tube in the filter is perhaps 9 - 12 inches above sea level and this is presumably affecting the priming procedure once the water has drianed out through the saildrive inlets which are well below the hull.
Last month's re-launch went like this:
Stb engine started. No sign of any exhaust water. Blipped throttle. No sign. Blipped again. Water starts.
Port engine started. Some water appears but then stops. Throttle blipped. Water starts.
We start to leave the hoist and I say to SWMBO to nip across and check both exhausts. She looks over the stern quarters and says both are OK.
We set off. After 30 seconds I ask SWMBO to check again. She asks why as she's only just checked. I ask her to humour me. She looks over the Stb side and says it's fine. She looks over Port side and says "It's stopped. Nothing there"
I guess that's it's airlocked so pop her into neutral and blip again. SWMBO confirms that the water flow has re-appeared.
We check again all the way back to our berth but everthing is fine now. I start the engines the next day and the water flow is instant, as it always is .... until we have our next lift out.
I wonder if others have a similar experience? If so, the moral clearly is "When leaving the hoist keep a very close eye on the exhaust/s and don't assume anything".
Richard
Richard
