Chiliblue
Hi,
I am planning to add a Vyacht net 'wifi nmea/seatalk multiplexer' and an ais receiver to my boats set up.
The ais targets won't show up on my old raymarine plotter/radar but that's ok, I always have my tablet on me I I use that for passage planning and just transfer the waypoints to the plotter unit. I would however really like to have the instrument information sent out via wifi.
My system is pretty simple, gps is fed to the seatalk using the ST60 multi nmea input, power is brought in to the ST60 multi via one of the seatalk ports, the other instruments are daisy chained off the other Seatalk port on the st60 multi > st60+ tridata > st60+ wind > plotter/radar.
The plotter only has on single seatalk port.
Ideally I would like to interface the Vyacht unit with seatalk rather than nmea, because although the st60 multi adds in the nmea data to seatalk I am not sure if it outputs the compatible seatalk sentances to the nmea out on the unit.
Does anyone have any thoughts on how I can do this with the equipment at hand? Would wiring the data and gnd to the Vyacht from the seatalk port that is also bringing in the power work? Or am I wrong about the span of data the st60 multi will output on nmea?
Thanks in advance.
Thanks in advance.
