Sealing ply
Tamar
9 Apr 2019
All over the shop
I've been given a nice sheet of exterior 18mm ply. I'm using it on part of my wheel house that sometimes gets wet but not soaking. Its exterior ply coming off. It's lasted 36 years so please no lectures about using marine ply?
Anyway the edges are perfect at the moment but I have to cut to fit.
What is the best thing to seal it all, especially the edges, I was thinking two pack?
I usually use epoxy or poly resin. You may find some filler where you cut, if so deal with that first.
My bet is you instead get lectures on how 36 year old ply was amazing and this modern new fangled stuff out of China is hopeless, although you're in Scuttlebutt so may miss the worst of this ?
I use warm epoxy resin with a little solvent like acetone aswell as warm the job, this will soak in lot better and add enough layers untill it no longer soaks in. With Poly resin i use styrene if you go that way. epoxy is best though.
+1 for epoxy resin. If you warm the plywood the epoxy will soak in further
But stop warming it about 5 minutes before you apply the epoxy. You want the ply to be cooling so the air in the wood is contracting and will then draw the epoxy in. If you continue to heat it you will get outgassing where the expanding air makes bubbles in the epoxy as it escapes.
Also don't heat the wood too much. Tropically warm is what you want, not hot. Too warm and the epoxy will kick off too soon and not soak in.
Take great care with fastenings. Any screws or holes you drill will need to be carefully resealed otherwise the moisture will get in, and wick up through the laminates. Once that happens it rapidly turns to cardboard. Rain and spray is just as effectve as immersion if the epoxy seal is compromised.
Pity you are not closer, I could have bunged you a litre or so. I scored a 200lt drum + assorted hardeners. Building a small ply cruiser and a friend doing similar with it. Saved a bundle on resin.
