Sealing cabin sole boards
strato
New Member
8 Jul 2021
I have just sealed the undersides and varnished the topsides of all my cabin sole boards. When screwing back down should a place a rubber seal around the edges to stop water from the bilges sloshing up or is it best to leave air to circulate?
Leave air to circulate IMHO ... nothing worse than mouldy seawater stink !
I would agree - but I guess it depends on how much of a problem sloshing water is for your bilge/cabin sole design. I have a deep bilge and haven't noticed any water coming out of bilge yet. On a different boat with shallow bilge I have had water coming through but I would try to fix the ingress cause rather than try to seal the cabin sole.
I agree that ingress should be sorted if possible ..... but many boats like mine - you get collected condensation running down into bilge ... mishaps etc.
Thanks, I have two accesable bilges that collect water, when sailing the water sloshes up & water then gets below all the other boards that are screwed down, it's these boards I'm thinking of sealing.
Welcome to the forum strato. Don't seal. Sloshing water has considerable force behind it and the sealing method your suggesting is likely to be inconsistent and provide a low quality seal. The seal will likely fail resulting in what you are trying to stop. Far better to put the effort into diverting bilge water to a common area and pumping out with a small electric pump, if you cant stop water from entering the boat.
Which is pretty well what I do ... main bilge area has an auto pump that discharges through the sink overboard.
