Sealine T50 water tank
seamikk6
22 Jan 2025
Hi
When I pour water into water tanks to the full I suspect that when is full that tube to water tank is damage somewhere on the top where I pour. Anybody have similar problems? I think that should dissamble in the master cabin closet in the left corner or for start left wall and the celling. Anybody knew how to disamble celling? It is screwed or glued?
Thank you!
Great idea. I didn't think of that. But maybe will work yes...I should look if is not the hose somewhere fixed, because seems very fixed but yes good point to try this,
First will put down the hose on the water tank and will blew into the hose to see if is going out air or will make preassure. In case is preassure then it is not damage the hose.
