Sealine S42 centre fuel tank
Dave1966
Active Member
5 Jul 2020
Good evening,
Does anybody have any idea how I get to the centre fuel tank? I need to change the fuel sender and I can’t see a way to get to it? Thank you
Good evening,
I don’t think S42s have a central fuel tank but
S43s do.
Anyway that could just be numbering.
The fact is the ones with the 75s and shaft drive have a central tank. (I thought they were called S43s)
Stern drive models don’t.
S43s do.
43's do indeed have 3 tanks
Good evening,
Hi Dave not sure if you found the tank but on my boat you have to take out the cupboard under the steps down into the saloon.
S43s do.
If memory serves initial numbering was S41 with outdrives and S43 with shafts. It then shifted to S42 with both being an option and I think you are right about which had the third tank, which I think was to cater for higher fuel consumption on the 75s.
Your memory is correct.
Just looking at my Sealine 2002 brochure (It’s amazing what you hoard!)
It says the S41 has the KAD300 DP-G (leg) and the S43 has the TAMD74P (shaft)
I think some also had Yanmar 6LP / Bravo 3.
