pau1gray
On our S23 I noticed that the bilge pump works but only through the main switch and not the float switch. My initial thought's were that the float switch was U/S.
There are three wires that lead to the bilge pump and Float switch - Black which is the -ve and goes directly to the pump, Brown which is the positive feed from the bilge pump switch and a grey lead - which is attached to the float switch then connects into the brown lead. So when the float switch rises it provides 12V to the pump.
With everything disconnected the float switched showed open circuit when down and closed circuit when up - therefore the float switch is working.
When measuring the voltage between the grey and the black there was 12V shown on the meter, but when I put a bulb across the grey and black it would not light??
On looking at the wiring diagram it says that the float switch is powered from a fused supply in the service box (which all seemed to be correct - break fuse no volts - reset fuse then 12volts on the grey lead to the black lead) - but the lead is Blue/red at the fuse box and not grey.
I tried to chase back the grey cable but it disappears into some foam and I can't find where is comes out. I've also tried chasing the blue/red cable but that disappears into trunking somewhere in the service box.
Does anyone know whwhere these two cables go???
I have made a temporary fix by running an aditional wire to provide 12V to the float switch but this does not fix the problem rather just hide the symptom.
Any thoughts greatly appreciated??
