Sealants for windows and hatches
cliff
15 Apr 2004
various
Sika Flex if you don't want to remove them again or..... A butyl rubber bedding / sealing compound that can be removed later if needed.
"Artificial intelligence is no match for natural stupidity"
sailroom <span style="color:red">The place to auction your previously loved boatie bits</span>
colvic987
2 Sep 2003
north west england
thompsons roof and gutter sealant is a butyl rubber compound, i have used it for sealing a deck hatch, and in the process of using it to seal my windows, one of the other sailing mags s(^$*(&*^g T^%$y has a piece about sealing windows and they have used arbomast another butyl rubber compound..
Its messy to apply but once it has cured it is ok..
AndrewB
7 Jun 2001
Dover/Corfu
The sealants you suggest are not suitable for marine use.
You should use Sikaflex 291 if the sealant will not be in direct light, or Sikaflex 295 if it is (the latter is UV resistant). The only other sealant suitable for this application is 3M 5200.
Alastairdent
11 May 2004
Why?
graham
Theres an article in the latest Sailing Today about refitting leaking windows.They didnt recommend Sikoflex due to the difficulty in removing it if you need to in the future.
Alastairdent
11 May 2004
These aren't yacht windows, they are mostly hatches and rooflights bolted down onto wooden boards. the boards have a vinyl covering which is under the flanges of the hatches and rooflights. Watertightness depends on a sealant filling any uneveness and preventing capilliary action drawing in the water.
The plastic portholes are just crap. We will be replacing them with bronze at some point.
