Princess52
Hi people
I recently read on the forum of various retro fits of a Seakeeper Giro to Nick H boat recently. We bought out v52 new last July. Based out of Plymouth I have recently pondered the merits of the new Seakeeper 5 so got a price to retro fit. £36k. Appreciating that the boat was £850 ish (I think) to me 36k is still painful particularly as I could just Move to another anchorage that is smoother (which I have done a couple of times).
I suppose my question from those with Seakeeper Giros is wether it is worth it. I'm not even sure that I could get it past the wife at this point anyway.
The work required is;
1. Move and re-position 2 x Air con condensers
2. Remove the start and auxiliary ETA boxes
3. Move and re-route Crew cabin sink drain, supply and toilet cable
4. Remove and re-position Air con inlet skin fitting
5. Remove and re-position Generator inlet skin fitting
6. Remove and re-route cables and hoses
7. Chop tray mould out
8. Cut down existing stringers/beds
9. Remove transverse stringer
10. Build beds for Gyro onto existing stringers/beds
11. Reinstate transverse stringer
12. Fit Gyro
Gyro would fit centrally aft of the engines about 300mm forward of the rudder table,
allowing 100mm clearance below the Gyro to the hull would allow 750mm up to the underside of the crew cabin floor, the Gyro is only 617mm high.
12. Fit Gyro
