sabresailor
Seagull o/b a few q\'s
Hi - well my forty plus is now running!! tired the trick with the drill to re-magnetise it - nice spark now!!!
Will try saving old seagulls for a carb gasget set - but where else can I get a set for the villiers carb?
Gearbox - I assume the only place i need put oil is the 'gear box' at the bottom by the prop? I assume there is no where at the top end which needs oil.
Other than the 10:1 fuel mix, checking that water is being pumped through (& out the hole by the cylinder) + gear oil - I assume there is nothing else I should worry about?
Is it worth taking the botten end off & poking about in the 2 'legs' - or are they basically maint. free?
Any other help appreciated.
Mike
Mike
