davidpbo
The venerable Seafarer Voyager Depth Gauge has suffered severe moisture ingress over the winter. In commision it is somewhat protected by the spray hood, on the trailer it is not. I didn't pay too much attention to the misting on the screen it has always done that occasionally then cleared and stayed clear. I did not want to investigate it in case that killed it.
However the time has now come when something has to be done
Amazingly prior to removal from the boat yesterday, it appeared to be working apart from low level tone from the external alarm and some possibly eratic readings. When I got it home and opened it it was obvious that it was more than a bit of moisture, the circuit boards were wet.
I have disassembled the unit and the components are currently in the oven using the defrost setting which circulates air only heated by the oven lamp so virtually ambient.
Has anyone moved the the display (viewed from rear).
This is the pcb which shows serious signs of corrosion on the solder contacts.
Suggestions for removing? I am thinking contact cleaner and gentle brushing with a toothbrush.
If it has died, is there another display that can be used with the existing transduder? Cable terminates in a TV aerial UHF connector.
Does anyone have an old working display I can buy?
Does anyone have a cover for one?
When I reassemble it, should I get any indication that it may be working, e.g. display working, without the transducer connected as that is still in place on the boat.
