bonny
Hi,
I'm re-fitting all my fittings having replaced all my skin fittings due to a number of cracked nuts.
(See earlier post - check your nuts)
Fitting the skin fittings to hull - no problem - Sikoflex.
What sealant should I use on the threads to connect the elbows, seacocks, tails etc?
The originals seemed to have some form of setting sealant.
The problem is that in order to get the taps, bends etc pointing the correct way, the fittings could be upto one turn short of fully tightened. If a non-setting sealant is used, I feel things may move, especially when opening/closing the sea-cocks.
