sailorman
http://en.wikipedia.org/wiki/Thread_seal_tapeIsn't ptfe tape intended only for taper thread joints?
It certainly won't lock a parallel thread joint very well.
As I warned in a previous thread I used Loctite 275. It set before the ball valve was fully home, in under 2 minutes. It took two of us, a heat gun over an hour to remove. Was lucky I didn't scrap both the thru hull and valve in process.
From another thread ...Sikaflex 292 or cheaper PU40 works well ...
Could someone clarify which type of Sikaflex the PU40 replaces?
I use it instead of Sikaflex 291.
how about hermatite or bluemels to confuse you moreFrom another thread ...
So I'm now confused again.
I meant I'm confused about the equivalence of PU40 and Sikaflex.how about hermatite or bluemels to confuse you more
even hemp & paste would workI believe that PU40 is a suitable replacement for Sikaflex 291. Sikaflex 292 is a higher modulus version of it, giving a stronger film than 291. I have some difficulty in imagining a situation on a boat where a high strength sealant would be needed, if it is assumed that the bolting provides the strength while the sealant keeps the water out. I'm not saying there are situations where an adhesive/sealant is the only fixing method but there cannot be many.
I believe that PU40 is a suitable replacement for Sikaflex 291. Sikaflex 292 is a higher modulus version of it, giving a stronger film than 291...
Thanks Vyv. Perhaps 292 would be better for sealing round my stanchion bases, but that's getting too far OT.
