Jolly-Roger
New Member
I am trying to remove 2 Blakes seacocks on a Westerly Merlin, which have become seized. I suspect they were not used/serviced by the previous owner for the last 5 years! As can be seen from the photo, the space in which to work is very limited. I have succeeded in removing the outlet valve from the holding tank. I have removed two bolts from the larger seacock and the other two sheered off. I have tried hammering from below and prising the flange from above, but there is no movement. I suspect they are sealed in with resin or Silkaflex.
My next step may be to grind off the bolt heads and plate from below and then drill around the shaft of the seacock.
Is this the only way or does anyone have any ideas how to proceed?
