Crinan12
Hi
Do those sea cocks look okay? In photo 1 the red arrow points to a bit of my seacock (heads inlet )which I can wiggle about - photo 2 shows it more clearly maybe. Is this normal? I would have thought it shouldn't move. Also Is the nut the yellow arrow points to in photo 1 in the correct place?I would have thought it should be further down as in photo 3?
I've attached a few other photos - does everything look okay? I've no reason to suspect much is wrong but just wanted to check. The inside of the cone bit looks very rough. Is that anything to worry about ?
I did have a small leak from the heads outlet seacock - just a drip - what's the typical problem - does it usually just need tightened up ?
Thanks in advance
Douglas
Thanks in advance
Douglas
