James_Calvert
The recent post on seacocks got me thinking. What to do when they fail? The worst I've had is a Blakes nearly seize up... I removed the cone, popped in a wooden plug whilst I regreased it and put it back in again. Only possible because it wasn't quite seized, and the Blakes design is pretty robust and unlikely to fail elsewhere during the process. But what about if a gate valve had stripped its internals, or a ball valve had seized? OK I guess with my annual maintenance regime, at least I could get a gate valve apart, but there would be little point unless I had an identical spare from which to rob the innards (and I don't). And a ball valve has no serviceable parts anyway does it? So the only option would be repair by replacement. But I wouldn't want to do this whilst afloat unless I knew I could get it off easily, without damaging the skin fitting. So perhaps I ought to be including gate valve/ball valve removal and replacement in my annual maintenance regime? Or else accept that if one of these fail I can't safely do anything about it whilst afloat.
What does the forum think?
