Seacock fitting pleasantly surprised
Madhatter
23 Sep 2009
Minehead / boat Porlock (I hope)
wp.me
I have just replaced my 11/2" seacocks and was expecting a load of hassle taking them out but following a set procedure everything went really smoothly ;- removed the hoses ,bend seacock leaving just the flange nut and through hull fitting, but all the threads were resined in with no chance of undoing the nut (in such a confined space) so disc cut the nut and split it off, got the huge mallet out to attempt to bash out the through hull fitting - no go. Re-think, cut the fitting off inside leaving 1/4" standing , fortunately I had an exact size hole saw to fit over exposed 1/4" flange whizzed through that and the fitting just popped out leaving a nice clean hole to fit the new Marelon seacocks and fittings, sealed and fitted, plus new hoses and finished . No trauma , so thanks to all the members who have offered advice to so many other members leaving a large and varied selection of ideas on these here forums. So all went well due to the collection of ideas that seem to cover most eventualities.
David2452
6 Jun 2001
London & Fambridge
Did this not enlarge the diameter of the hole through the hull?
You would have to do that anyway, on say a 1 1/2" BSP fitting the OD is 1 3/4" but the Marelon through hull part is just over 2" oddly enough I did the same thing yesterday but didn't need to cut skin down fitting down as it broke under the flange nut.
sarabande
6 May 2005
saw the boat this afternoon. The more I look, the more I like her. Nice work, Marelon makes a lot of sense for the best fo reasons.
20 Jun 2007
Live in Kent, boat in Canary Islands
www.bavariayacht.info
...f ortunately I had an exact size hole saw to fit over exposed 1/4" flange whizzed through that and the fitting just popped out ...
Fine if you are enlarging the fitting. If not, I can recommend an "Oops Arbor" like this http://amzn.to/1oczQn2
Mine has been invaluable for enlarging hole saw holes, and will be perfect for when I drill out the through-hulls. You fit the larger saw in your existing arbor, then replace the 6mm drill with the oops, then attach the saw for the smaller hole.
