Daverw
Ours was fitted that way four years ago by mistake by me, never been an issue. Did worry about at first but now just get on with sailing
A fluid dynamicist writes ...
The highest pressure you can get that way is the stagnation pressure, caused by bringing a moving fluid to a stop. It's 1/2 density x velocity^2, so for a yacht doing 10 kt (5 m/s) in water of density 1000 kg/m^3, the stagnation pressure is 12.5 kPa. Since atmospheric pressure is 101 kPa, that means the highest pressure the scoop will generate be 1/8 of at atmosphere.
Since that's a head of 4 feet of water, it would probably get around a vented loop but I really can't see it forcing any significant amount past a vane impellor.
Furthermore, stagnation pressure is proportional to velocity^2 so at 5 kt it would be a head of only 1 foot, which on my boat is less than the change of depth of the seawater inlet when I tack.
... I wonder if anyone has sucked in a jelly fish yet, or had one block the intake. ...
How does that compare with the Bernoulli and pitot tube theories mentioned by Rogershaw in post 16?
That JumbleDuck.... the snit he knows!
Same thing. Pitot tubes bring the fluid to a stop; the pressure difference between that and the static pressure in the fluid moving past (yes, "static" pressure in a moving fluid ... I didn't invent this stuff) is the stagnation pressure.
What comes to mind as the quickest solution would be to drill a couple of holes in the blank part. 5 mins and job done!
fwiw, my yanmar 2GMF inlet has a forward facing scoop.
Following 5 seasons, no problems at all and that's on a mobo with the yanmar typically used when stationed (and not much)
Typical speeds are 8-9kn and an occasional blast at 18-19 (way too rare)
yanmar impeller below w/l
not a main engine, its the generator's engine!They're supposed to face forward on mobos.
normal main engines have forward facing scoops.
OK, just thought your calculation seemed much simpler than the formulae in the Bernoulli link.
It's many years since I studied fluid dynamics at university, and I have to say I've forgotten most of it!
Can I interest you in an economically priced update? No sails, I'm afraid, but it does include wind, weather, tides and waves as well as the usual flow-down-a-pipe and flow-over-a-wing stuff.
If one were to do that what is to stop the bit inside the hull from falling orf? My scoop is held in place with a single nut on the scoop’s spigot on the inside surface of the hull, which is sandwiched between the inner nut and the flange formed by the scoop.Just cut the whole scoop off flush with the outside of the hull with an angle grinder would solve any issue if there is an issue in the first place.
