Avalon
This weekend we will be flying out to Bilbao to finalise the purchase of our "new" Princess 35 which has Volvo TAMD41A engines and MS4 gearboxes.
The survey was favourable - indeed, quite complimentary. Unusually, the surveyor was able to perform a brief engine trial at low speed which did not reveal any problems. The engines are beautifully clean and give every indication of having been well maintained.
Before completing the purchase we will be conducting a fuller sea trial on Saturday. We would appreciate guidance on what we should look for.
Obviously we will be running the engines for a while at full power as well as at cruising speed. What should we look for in terms of water temperature and oil pressure - at idle and at speed? What RPM should the engines reach at WOT, and what should the top speed be in flat conditions with a clean hull?
I have read the discussions on the Volvo gearboxes which I konow are not universally held in high regard. Anything we should look/listen out for apart from the obvious?
I'll try to post a couple of pics, and will post more once the deal is done. Assuming it all goes through, the boat is due to to be trucked back to the UK shortly by Geoff Houghton of Boat Transport Ltd, at a cost of £4500.
