Sea toilet - Sealine 240
Barneyt
New Member
12 Jul 2011
Hi, I'm new to the Sealine 240 Senator. Does anyone know how the sea toilet system works?
i.e. does it discharge straight into the water or, does it have a holding tank and, if so, how to I empty that? Is it pump out or can it be discharged at sea? How would I do that?
Thank you for reading this.
if your boat is standard, its got a sea toilet (holding tanks were extra)...will go and try n find instructions for mine and get back asap.
I used to have a 240 with a holding tank. The tank was sited under the floor under the cabin table. If you have one you will have a filler cap on the deck about half way down. Pumping out (at sea) is done with a hand pump and I can't for the life of me remember where that was.
Quick check to get a idea if holding tank fitted is to try the waste switch, if fitted you should hear the pump, and the bar-graph also show a increase.
rian
I have tried the waste switch and it does whirr. I also have a 'waste cap' in the deck mid ships on the starboard side.
