ALPHORA
Active Member
Strange happenings with our electronics. The system is all raymarine, with a C120 plotter linked to ST60 instruments via Seatalk. The instruments are log, depth wind, and 4000+ wheel pilot, radar, and an ST70 repeater. The heading alignment on the autopilot has taken to resetting itself to apparently random directions. This also causes the boat icon on the plotter to wander off the true boat heading, which I suppose makes sense. I can realign the heading on the wheel pilot display and it stays put for varying lengths of time before wandering off. When it does wander I have seen the heading displayed count up or down by varying amounts until it settles on a new value, where it will stay, again for unpredictable times. Changing the boat heading is mirrored by the display, even if the numbers are rubbish, ie a change to port or starboard by a given amount is seen on the autopilot display. On its own this would point to a fault with the 4000+ control unit which I have no idea how to check. Yesterday the depth display changed to look just like the autopilot display with heading, standby etc. Pushing buttons on the depth display had no effect, turning all the instruments off and on again changed it back to a depth readout. The wind instrument also gives wayout readings occasionally, over or under reading by large values. The speed display is also prone to giving odd values, and this appears to be caused by the calibration factor being reset. I have checked all the connections on the system several times and all appears sound, visually and with a multimeter. I have also isolated each instrument and they appear to work fine , but it is difficult to be sure as the times between the odd values appearing can be a few seconds to weeks, but the autopilot errors do seem to be cropping up more often, at shorter intervals. None of the instruments has been added recently, all worked happily together for about 4 years. The batteries are all good and the voltage has never been below 12.8v when the faults appeared. Charging is by a combination of wind and solar when we are underway. I have tried turning everything else of an electrical nature off and it seems to make no difference. Is there something obvious I have missed? Time to get out the Walker log and sextant? Help.
