panda9958
Do ignition switches fail ? I have a 4 year old 220 Sun Sport .
Sometimes when you turn the key the ignition is dead. If you turn it left the radio works ok. I've checked all the wires, the fuses and the fuse block itself and can find nothing wrong. This leaves me to think the problem may be with the switch itself.
If anyone can suggest anything else I should check before replacing the switch I would really appreciate it. Not very keen to take the boat to sea until I track down this problem. I did think , as a last resort, I could 'hot wire' at the back of the switch !
Thanks.
Thanks.
