Johnny WAFI
Hi all
What is the life expectancy of the original seacocks in a Sadler 29? Should I be doing something?
If they are Blakes then just do the regular maintenance. If ball valves then they are likely to be bronze if original. If gate valves get rid of them and replace with DZR or composite.
If they are like ours were, most will be blakes. Service once a year when out of the water (lots of instructions on line), and they will last as long as the boat. The exception may be the engine seawater inlet - ours was a 1/2" ball valve, which was replaced with 3/4" DZR skin fitting / ball valve / hose tail when we re-engined. As you are looking to replace your Bukh, you may well need to do the same...Hi all
Their biggest weakness is crevice corrosion on the threads. Underwater valves create perfect conditions for crevice corrosion of the threads of both valve bodies and fittings where oxygen starved water sits in the threads. Much the same with plain brass where galvanic action start the dezincification process. Failure of yellow metal seacock/valves is almost always in the threads of fittings, both through hulls and hose tails. Using bronze, DZR or composite avoids this.Tranona
What is your view on 316 stainless steel ball valves as a seacock
I fitted 3 part stainless steel ball valves for ease of servicing
