Sea breezes
Yealm
13 Apr 2017
Sorry, probably basic schoolboy question..
Do weather forecast apps (I use XC Weather), take into account local sea breezes?
My boat is really only happy >10 knots, Summer forecasts are usually less- but is it still worth going out, in hope they’ll be stronger local conditions? Or if you select a coastal location does the app take into account local sea breezes anyway?
oldharry
30 May 2001
Sometimes mentions the possibility, but it's often too local and unpredictable to forecast accurately.
Look for small fluffy clouds building a couple of miles inland by around 10.30 -11.30am. that means the heating land is creating updraughts which draw the air in off the cooler sea. Not infallible but usually a pointer in settled weather. Sea breezes often establish around 11.00 - 12.00, and start to fail around 4.00pm as the sun sinks lower. Then there is the more complex subject of modified sea breezes..... !
The Q
5 Jan 2022
With this heat we'll likely get a sea breeze tomorrow some time between 12:00 and 14:00 on the Norfolk Broads probabley from the North east. That's not normally forecast but this time it coincides with the wind switch from westerly over the top to a south easterly. So for a change we shouldn't get the dead time when general wind fights the sea breeze.
