Halo
Hi All
The oil in my Yanmar SD20 sail drive has turned to egg yolk. This means water is getting in. I replaced the drain plug o ring last time out of the water so I am now replacing the prop shaft seals. I suspect the seals may have been put in the wrong way round last time. I have the service manual but cannot make out for sure if the hollow side should be on the sea water and oil side ( both blank faces facing each other) or with the two hollow sides together in the centre. Can anyone say for sure ?
