zachs
Hi all,
I have a 1GM10C with SD20 drive installed in a Columbia 26 MKII. 2 weeks ago I went to check the oil level in the SD20 and there seemed to be some backpressure which made oil come up out of the oil fill. Not too much, but enough to know that something wasn't right. After thinking about this for a bit I finally came to the conclusion that water must be leaking into the oil from somewhere down below. Things that led me there were 1. Backpressure on oil. 2. slightly milky consistency of the oil. Relating to the milky consistency the oil had been like this for some time (at least 8 months).
Later last week I had the boat hauled for paint, zinc's, and other maintenance and I figured I'd replace all the seals in the lower unit. (Including the gasket around the oil drain plug). Nothing seemed too out of the ordinary, meaning no obviously broken seals.
So I have thrown the whole thing back together and am hoping for the best at this point.
I'm looking for advice on any other items I should check before putting her back in the water? Or if any one has seen this behavior on this drive.
Thanks in advance,
Zach
Thanks in advance,
Zach
