chrishelen
N/A
My white GRP boat is out for its annual spruce up, along the side I moor up are a few of the above, some are dark from off the pontoon wood. I have tried to scrub them out but they are still there. Any ideas?
The T-cut may help, no harm in trying.
One or more of the following may help, but won't repair any gel coat, just help to dig these out of the highs and lows of the surface.
Acetone, with a microfibre. This will deal with the rubs from the rubber marks.
Water and a melamine sponge will hook out any staining debris from within the gel.
If these fail then I would agree with Len Ingalls above and say you were into using wet n dry, but perhaps a little finer than 400, maybe try 2000 first.
If you can catch your nail in the scuffs then you are into adding more gel, don't be tempted to sand these out or they will just leave a ripple.
If you do sand, then use a block so to go into the gel evenly.
