Screwfix sealants
ghostlymoron
9 Apr 2005
Shropshire
I'm just looking through the screwfix catalogue for suitable sealants for bedding skin fittings. I'm confused, I don't really need an adhesive (especially if I ever want to remove the fitting in future) so what's wrong with a basic silicone sealant at £2.19 a pop?
Anthony
8 Sep 2003
Western Australia
The polysulphide works well when I have used it above the waterline, personally I would pay the £8 for the Sikaflex and sleep at night without worrying about it.
Clyde_Wanderer
15 Jun 2006
Glasgow
Sikaflex should NOT be used on plastic fittings, especially below the waterline, for this purpose use Lifecaulk.
For any type of metal fittings I use Sikafles 291, which is actually easy enough to get off with a sharp blade when nesseccary.
Clyde_Wanderer
15 Jun 2006
Glasgow
Never ever use silicone below the waterline.
tobble
4 Oct 2005
Cardiff
could you expand on this please?
Sheff
5 Oct 2005
1) Don't use anything from Screwfix, it's not appropriate to marine use.
2) Don't use sikaflex 291, it's a glue, it bonds, like the proverbial to a blanket!......... you may want to remove what you're fixing.
As mentioned by some, you want a polysulphide sealant.......... just means it remains flexible over time and can be removed.
Flossdog
8 Oct 2006
West Wales
Northshore have bedded my lifting keel grounding plate with silicon. No watertightness is needed and it seems OK after 8 years. Obviously it might need to come off and if they had used Sikaflex 291, well, it would never come off!
