So is the firing range east of Nieuwpoort? I can't find anything on the charts and my Reeds is on the boat.Yes they will be firing until and incl.the 14th June before breaking for the summer so avoid the Nieuwport firing range if before 1600 hours when they finish.
After 0800 and before 1600 that really means staying west of the large Westdiep mussel farm .Coming from Dover you should be clear ,and probably arriving late,but would be affected during any onward journey east.
The 2.5 NM (K range) and the 7.5 NM (M range )seaward limits are best shown on the O charts series or Marine Navigator (VMH series) but if using a tablet.Navionics is less clear.
Go to the end of this thread for dates. Nieuwport Firing Range
Sorry if you are aware.
We are crossing from Ramsgate to Nieuwport on the 11th. but won't expect to be stamped in until the 12th. A moderate westerly is currently being shown on the gribs for the 10th at least.
You’ve probably seen the floating end of a pipe used for beach suppletion. There are currently two such points between Nieuwpoort and Oostende, both clearly marked by a N cardinal. It is only the extremity to which the dredger connects that floats, the rest of the pipe is on the sea bed, so you can safely pass between the floating bit and the beach.Not just wrecks, we came across a large floating hose not marked officially, a community edit showed it on Navionics charts.
Close to the beach you will clear the firing range quickly, as it is less than 1 NMYes ,the firing points are to the east of the entrance.Coming from Dover you will probably not have an issue.I have previously come in after heading North with the tide and wind from Ramsgate and dropping back down around the shipping giratory to cross the zone near their seaward control tower but at 5 kts this was after 1600.
We will be continuing east so will probably have to leave early and cross the range close-in before 0800 - from memory about 4nM to clear the 'cone'which we will probably motor.
They may not fire on any particular day for their own reasons or for the whole working day.
If needs be you can check by calling the range while it is manned. Tel +32 58 23 64 60 or VHF 67.
Useful, thanks, is this the police building?Thanks for all the advice. We got into Neiuwpoort just after six yesterday evening. The marina office at VYN was shut but there's plenty of room for late arrivals on the hammerheads. Then the police called me and said they were open till seven so we nipped up to their office and got our passports stamped.
All very friendly and helpful here.
Yes indeed. The police office is on the east side, close to the barrier you see in the picture
